Good morning.
I'm doing a drawing of an i-assembly which has (4) members. This i-assembly contains several parts which are only present in certain members. In the screen cap I am attaching, you can see that in the Parts List manager, I have selected which instance I want the parts list shown for, and have checked the box to hide zero quantities. However, in the Parts List table, all parts are shown. This is also true in the table placed on the drawing. The only option I can see is to statically remove (hide) the zero quantity parts, and I'd prefer not to do that. Is this a known issue (bug) or have I missed a step somewhere?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Solved by zma1013. Go to Solution.
Hi! In the iAssembly factory, could you tell me how you configure the parts for each member? Did you use "Include/Exclude" status? Hiding the components would not make them disappear from BOM, since visibility does not control BOM.
Thanks!
I believe I used "compute/suppress" in the i-assembly table. Is that the same as include/exclude? I will look into this later when I can get back to that job, and I'll report back how it went. Thanks Johnson!
Chris Benner
No, "Compute/Suppress" is a feature level control. It dictates whether or not a feature (not a component) will be computed or suppressed for the particular member in the iPart/iAssembly. To control component participation, you will need to use "Include/Exclude."
Please open the iAssembly factory file and edit the table. Go to Components tab or Exclusion tab and find the component. Then add the "Include/Exclude" item to the author table. Please keep in mind the visibility does not affect component quantity or the BOM table.
Thanks!
OK,... most of the components of the i-assembly are themselves i-parts. I used "include" on the components, and "table replace" to get the correct instance of each i-part in order to make all the various versions of the assembly. Screen cap of the table is enclosed. I fuzzed out anything proprietary,... that's why all the yellow.
Chris Benner
Hi! In the snapshot, do you see the first item "Include/Exclude" in each component node in the Components tab? Just click it and it will be added to the table.
Thanks!
Did that, and the parts list still shows all items, including those with zero quantities.
Not a big deal, I can just manually take them out.
Chris Benner
Hi! When you edit the Parts List->Member Selection, did you see the checkbox "Hide rows of zero quantity"? Is it checked? On my machine, if the option is checked, there is no need to manually remove the item with zero quantity.
Thanks!
Yes, that option is checked.
Chris Benner
I believe that for the parts list to show the correct quantities in the idw of an IAssembly member you have to have the model open and activate the member for which the idw and parts list are drawn.
Try that to see how it works. I do a lot of IAssemlies and find them very powerful. There still needs to be a bit of work done on the drawing / documentation side though to deal with these types of issues.
Mike
Older thread I know, but I may have found the reason why the rows are still showing.
Note: The option works for QTY property only, it does not work for ITEM QTY or any custom property.
It's pretty stupid if you ask me.
Yes, this is very stupid. It's been a while since this thread was updated, is there now any way to hide rows with zero quantity without having to include the "QTY" column?
Hi @DRoam
I agree with you, it's so stupid !
I've got the same problem in the past, and @Curtis_Waguespack found a fix with an iLogic rule in this thread (post #14/33).
I've modified his code :
SyntaxEditor Code Snippet
' Set a reference to the drawing document. ' This assumes a drawing document is active. Dim oDrawDoc As DrawingDocument oDrawDoc = ThisApplication.ActiveDocument ' Set a reference to the first parts list on the active sheet. ' This assumes that a parts list is on the active sheet. Dim oPartList As PartsList oPartList = oDrawDoc.ActiveSheet.PartsLists.Item(1) ' Iterate through the contents of the parts list. Dim i As Long 'look at each row For i = 1 To oPartList.PartsListRows.Count oRow = oPartList.PartsListRows.Item(i) 'look at each column in the row Dim j As Long For j = 1 To oPartList.PartsListColumns.Count 'look at the cell value Dim oCell As PartsListCell oCell = oRow.Item(j) If oCell.Value = "0" Then 'oCell.Value = "" 'clear the cell oRow.Visible = False End If Next Next
But like me, i suppose you would want a fix without an iLogic rule
Thomas
Mechanical Designer / Inventor Professionnal 2023
That's great, @ThomasB44, thanks! That will be helpful.
It would be even better if it could:
This way I could just run the rule before printing a drawing and be confident that all Parts List have been updated appropriately.
If I find the time I could possibly figure out how to add those functions in myself, but if someone else finds the time before me and wants to tackle that, that would be great!
But yes, a built-in solution would definitely be much better.
Yes @DRoam, if i have a little time for this, i will try too, perhaps tomorrow.
And also, this rule needs to run with exception cases :
And a final message "X parts lists updated" to have a really cool use
Thomas
Hi ThomasB44 and DRoam,
I anticipated an issue with iterating through the columns and turning on/off rows that had zero, in that the code as previously written was likely going to turn it off, and turn it right back on when it went to the next column, which would have made it seem like nothing was happening.
So I was going to provide a quick example where it just calls the QTY column... and then I just added this wish list while I was at it.
I hope this helps.
Curtis
'check file type If ThisApplication.ActiveDocument.DocumentType <> kDrawingDocumentObject Then MessageBox.Show("Come'on, what-a'ya tryin' ta'do to me here?" &vbLf & "This ain't no drawing!", "iLogic") Exit Sub End If ' Set a reference to the drawing document. ' This assumes a drawing document is active. Dim oDrawDoc As DrawingDocument oDrawDoc = ThisApplication.ActiveDocument 'Define the drawing sheet Dim oSheet As Sheet 'capture the current active sheet Dim oCurrentNumber As Sheet oCurrentNumber = oDrawDoc.ActiveSheet Dim iCounter As Integer iCounter = 0 'set default ' Iterate through the sheets For Each oSheet In oDrawDoc.Sheets oSheet.Activate ' Set a reference to the first parts list on the active sheet. ' This assumes that a parts list is on the active sheet. Dim oPartList As PartsList Try 'set to first parts list on the sheet oPartList = oSheet.PartsLists.Item(1) 'increment counter iCounter = iCounter+1 Catch 'catch error when no part list 'comment the next line if you don't want a message here MessageBox.Show("Yo, there ain't a parts list on 'dis sheet.", "iLogic") 'jump to named place Goto Jail 'do not pass go, do not collect $200 End Try ' Iterate through the contents of the parts list. Dim i As Long 'look at each row For i = 1 To oPartList.PartsListRows.Count oRow = oPartList.PartsListRows.Item(i) 'look at QTY column 'look at the cell value Dim oCell As PartsListCell oCell = oRow.Item("QTY") If oCell.Value = "0" Then oRow.Visible = False Else oRow.Visible = True End If Next'row Jail: 'named place Next'sheet 'return to original sheet oCurrentNumber.Activate MessageBox.Show(iCounter & " parts list(s) updated.", "iLogic")
Curtis Waguespack: "Oh, by the way, while I was passing by I thought I'd just solve all your life's problems. That ok?"
Yes, Curtis, that's fine. How many times are you gonna make us say "You da man!"?
Thank you for once again providing an excellent solution in record time. Can't thank you enough! And thanks, @ThomasB44, for getting the ball rolling!
Oh, and love the humor in the code by the way lol
@DRoam wrote:
How many times are you gonna ...
You can blame ThomasB44 I saw he mentioned the other thread, and then when I looked in to see what was happening, I saw the line: "For j = 1 To oPartList.PartsListColumns.Count" and that jumped out at me and looked like trouble (meaning that I got wrapped around the axel with this trying to do something similar in the past.)
Happy to be blame
Thanks a lot @Curtis_Waguespack for this code, and your funny comments
And thanks @DRoam you're right about the Curtis super power :
"How many times are you gonna make us say "You da man!"? "
Thomas
1. check "on" your Hide rows of zero quantity in the Select Member box (upper right icon in the Parts List edit box).
2. in the "Column Chooser" insert the property "QTY" to the BOM.
3. make the "QTY" column width 0.0. This will hide the column.
Make sure you use the property "ITEM QTY" for your actual BOM quantity.
