Can I assume you have connection points at the ends of all of the values and
at each of the ports on the solenoids? If you then YOU DA MAN!! I started
looking into this for pneumatics but I quickly gave up and feel back on my
library of AutoCAD symbols.
Way to go Quinn....(That is, if you share)
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Quinn Zander" wrote in message
news:627DFDB8E9CF9998ADBFF14BDE5E7F68@in.WebX.maYIadrTaRb...
> I have placed a PDF doc of a list of Sketched Symbols I have created to
> illustrate Hyd.Schematics directly in IV's IDW enviroment.
> In order to create at least a workable list of symbols, I would appreciate
> any input/requests to add to the list.
> Of course the valve symbols are virtually endless with respect to
> configurations.
> The ability to scale and rotate(and specify connection points) Sketched
> Symbols in R6 has made undertakings such as this quite feasible.
> QBZ
