Inventor Forum
Hydraulic Sketched Symbols-Input Wanted
2 REPLIES 2
148 Views, 2 Replies
I have placed a PDF doc of a list of Sketched Symbols I have created to
illustrate Hyd.Schematics directly in IV's IDW enviroment.
In order to create at least a workable list of symbols, I would appreciate
any input/requests to add to the list.
Of course the valve symbols are virtually endless with respect to
configurations.
The ability to scale and rotate(and specify connection points) Sketched
Symbols in R6 has made undertakings such as this quite feasible.
QBZ
2 REPLIES 2
Can I assume you have connection points at the ends of all of the values and
at each of the ports on the solenoids? If you then YOU DA MAN!! I started
looking into this for pneumatics but I quickly gave up and feel back on my
library of AutoCAD symbols.
Way to go Quinn....(That is, if you share)
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Quinn Zander" wrote in message
news:627DFDB8E9CF9998ADBFF14BDE5E7F68@in.WebX.maYIadrTaRb...
> configurations.
> QBZ
Oh, yah!.... connection points all over the place!
I'm still looking for a Cross-Port-Relief Valve, and a Counterbalance Valve.
I just added a Shuttle Valve (tee fitting with a check ball)
Charles sent me some Piping & Instrumentation DWG symbols he did up... I
guess this means I'll have to install MDT on my nice clean box.
I'm not sure if importing DWG's into IV symbols would be that much quicker
to create the library. ? .
QBZ
"Sean Dotson" wrote in message
news:3613B0DD701397D74606075CB72099FE@in.WebX.maYIadrTaRb...
and
started
