Inventor Forum
Hurt my wirst badly
17 REPLIES 17
Message 1 of 18
697 Views, 17 Replies
Hurt my wirst badly
I use IV all day long with regular mouse and my wrist hurts very bad.
I tried to create many hotkeys on the keyboard and spacepilot, however,
still need to drag thing with the mousse
Just wondering if there is any kind of mouse on the market to avoid rest
your wrist while moving mouse
Thx
IV11 Pro. spxx
Window XP Pro sp2
Pentium 3.2 Ghz, 3.0 GB of RAM
NVIDIA FX 3400 8.1.7.2
17 REPLIES 17
Message 2 of 18
Some have used this
http://www.3m.com/us/office/myworkspace/mos_ergo.jhtml
Mike
"Chris (IV11 Pro. SPxx)" wrote in message
news:5165453@discussion.autodesk.com...
Thx
IV11 Pro. spxx
Window XP Pro sp2
Message 3 of 18
TGPE
Quite a lot of us use Space Ball type controllers to move views around. I personally much prefer to use a trackball rather than a mouse for dragging things around in the graphic window. The trackball is not that expensive. If you can get one to try, you might like it.
HTH
TOM
Message 4 of 18
Says it's available in two sizes, small, medium and large. Bob
Message 5 of 18
Actually, it says "small/medium and large".
Mike
"Bob Johnson" wrote in message
news:5165501@discussion.autodesk.com...
Message 6 of 18
Anything I could use without resting my wrist on the mousse pad would be
perfect
wrote in message news:5165500@discussion.autodesk.com...
HTH
TOM
Message 7 of 18
3d ergonomic mouse seems to be the one I'm looking for ...
"Mike Maenpaa" wrote in message
news:5165464@discussion.autodesk.com...
Some have used this
Mike
Thx
IV11 Pro. spxx
Window XP Pro sp2
Message 8 of 18
I took one of those long raised pads you put in front
of your keyboard, cut it in half, and use one half
in front of my mousepad, and the other half in front
of my space traveller.
Bob S.
Message 9 of 18
> Thx
I've been using a large track ball for years. Whenever I have to use a
mouse or a small ball, I try to find an excuse to leave the building.
The one I have is an older "Kensington Expert House".
The ball is the size of a pool ball, about 2.25 inches diameter. In
fact, I hear that it is made by the same people who make billiard balls.
As I recall the pool ball was slightly smaller and less "round". Yes,
I tried to replace it with an 8-ball just for fun, but is didn't work. A
big plus for any track ball is that you don't need much desk space or a
pad. You can put on your lap or leg if needed. The only thing I added
was one of those squishy cushions for the wrist support.
Billy Hiebert
HIEBERT SCULPTURE WORKS
Small Part Injection Molding
http://www.hieberts.com
Message 10 of 18
James86004
I use that mouse, and I love it.
I actually was diagnosed with carpal tunnel, and with a few changes suggested by my doctor, the pain has gone completely away.
The most significant of his suggestions:
You need good, adjustable armrests on your chair, so that you can support your elbow so your forearm is parallel to the floor.
I ended up with a $500 chair - expensive, but cheap compared to surgery.
Message 11 of 18
Phil PDX
I have used a track ball, trackman or whatever, the logitech thumb marble since R2.
I am 6'3" and my paws dwarf the things but with a few creative mods it is very comfortable. Right now I have it on two thick foam mouse pads tor 5/8" elevation.
My station is L shaped and I sit in the crotch of it so my arms rest on the desk while working. I guess the key to ergonomics is to find what works for you, including your wrist.
Regular mice should be outlawed for bad ergonomics, besides a marble is way more accurate for picks and such.
Message 12 of 18
Hello Chris,
Years ago when I had severe carpal tunnel, I used a tablet with a stylus.
It worked out really well. Get the ones w/o the batteries though, it made
the pen top heavy. It may not sound like much, but after 6 or 8 hours, your
index finger felt it.
Thank you,
Bryan
bryan.kelley@autodesk.com
Technical Liaison - Rapid Response Team
Autodesk Inventor®
Manufacturing Solutions Division
Autodesk, Inc.
7995 SW Mohawk
SouthCenter, Bldg A
Tualatin, OR 97062
Tel: (503) 692-8335
Fax: (503) 692-1630
Thx
IV11 Pro. spxx
Window XP Pro sp2
Message 13 of 18
I have a desk for my work station at home, it is an "L" shape to my right,
so I can rest my right arm on it and use the mouse. I've had the carpel
tunnel syndrome before, it is quite unplesant. The way my desk is set up
really takes the stress away from holding my arm up in other situations.
Russ
http://www.tannersacre.com
wrote in message news:5165563@discussion.autodesk.com...
Message 14 of 18
veefourbloke
Hi Chris
Like some others here I use a trackball mouse. At the moment my weapon of choice is the Logitech cordless optical trackman. I use it in conjunction with a wrist rest. My left hand weapon is the wonderful spacepilot. Hope this helps.
Regards
Ade
Isoma
Derbyshire
England
Message 15 of 18
xavierl
I would also go for the very expensive contoured office chair, that can be adjusted so that the armrests are slightly above the desk level.
If your forearm is not supported, then you will start feeling pain in your neck muscles and all the way down to your hand.
My back and neck pains disappeared one day after getting the chair.
GO for the chair first and then the fancy mouse.
regards
Frans X Liebenberg
cape town
Message 16 of 18
I never used a tablet with a stylus. Can you recomend which one would be
used with IV
Thx
; "Inc.)" wrote in
message news:5166153@discussion.autodesk.com...
Hello Chris,
Thank you,
Bryan
Autodesk Inventor®
Autodesk, Inc.
7995 SW Mohawk
SouthCenter, Bldg A
Tualatin, OR 97062
Tel: (503) 692-8335
Fax: (503) 692-1630
Thx
IV11 Pro. spxx
Window XP Pro sp2
Message 17 of 18
Hello Chris,
At that point in time there was no Inventor, MDT, AutoSurf, or Designer,
just AutoCAD R12. At that point in time it was a small Calcomp tablet I
think.
Thank you,
Bryan
news:5167194@discussion.autodesk.com...
used with IV
Thx
; "Inc.)" wrote in
Hello Chris,
Thank you,
Bryan
Autodesk Inventor®
Autodesk, Inc.
7995 SW Mohawk
SouthCenter, Bldg A
Tualatin, OR 97062
Tel: (503) 692-8335
Fax: (503) 692-1630
Thx
IV11 Pro. spxx
Window XP Pro sp2
Message 18 of 18
Closterman
Just another suggestion (who really help me ! ) Use a Spaceball. You will save more than 40% of mouse movement.
Look on e-bay, you will find some for 25% of the price.
You will reduce your mouse movement and also add your productivity. I had some wirst problem in the past and this really help me. But, a good chair and desk are better than the Spaceball... ;0)
