Inventor General Discussion
Valued Mentor
SeanFarr
Message 1 of 3 (1,244 Views)
HSS Assembly - What Weld Symbol Should be Used?
1244 Views, 2 Replies
01-15-2013 07:23 AM
Good Day All,
I have attached a screen shot of a HSS frame structure. The tube is 4"x3"x1/4". There are many joints, but this particular joint is giving me a hard time to detail. I have searched around and have found nothing conclusive on how to annotate this joint on a drawing.
There are 2 types of welds to ensure that a weld bead is placed around the entire tube, a fillet weld where the faces are perpendicular to each other and then a flare-bevel weld (red arrows on image) where the round of the tube meets back up with the end face of the opposite tube.
Do I need to apply 2 separate weld symbols for this type of joint or is it understood in most fabrication shops if a simple fillet weld symbol is placed.
Thanks!!
Sean Farr
Sean Farr
Product Designer at TESInc.ca
Inventor Professional 2014-Update 2 - AutoCAD Electrical 2014
Win7-x64 | ASUS P8Z77-V | i7 3770 -3.4 GHz | 32GB RAM |
240GB SSD | nVidia GTX 670 4GB - 320.49
blair
Message 2 of 3 (1,223 Views)
Re: HSS Assembly - What Weld Symbol Should be Used?
01-15-2013 09:26 AM in reply to: SeanFarr
If I placed two separate weld symbols on a joint like that, I would probably get a call from my shop floor to explain myself. They would be looking for a fillet weld symbol with leg length and the all around symbol. If it was a shop dealing with aviation equipment two symbols and note would be required.
IV2015 SP1 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 344.60
SpacePilot Pro 3.17.7, 6.17., 4.11
Delta Tau Chi ΔΤΧ
Valued Mentor
SeanFarr
Message 3 of 3 (1,210 Views)
01-15-2013 11:13 AM in reply to: blair
So your shop can interpret what needs to be done in those types of cases. But to be safe, Should I annotate that weld with 2 different weld symbols? I just wasnt sure what the second weld symbol should be where the end face of the tube meets up with the round of the opposite tube. It would be the flare-bevel-groove weld??
If I were to use 2 symbols to ensure proper weld beads applied, would this ensure that the weld bead go all the way around the joint. There would be no gaps in the corners of the joints?
Thanks for all help!!!
Sean Farr
Sean Farr
