Hello.
I am a student of CNC ,CAD, and CAM and have learned the basics of inventor and was tasked by my teacher to find a tutorial on HSM Express and learn it.
So I found the tutorials in the help section of the CAM RIbbon button in Inventor Proffetional 2014 and I understood how it worked and so on, up untill a point where it simply ignores what you expect it to do, completely. I came to the last part of the second tutorial and was/am trying to complete the "chamfer" outside the tutorial 2 stock piece, but it simply refuses to do an outside 2d contour.
I then made a little testmodel and tried to replicate the error, and voila, same error.
as you can see in the images I have linked I can not understand why this is happening, I am doing exactly what the tutorial says to do, only altering what it tells me to.
My testmodel is simply a bow with two holes partly cut our from it and a chamfer around it.. I will attach the file if anyone is interested, this is the exact same thing that happens with the tutorial file.
The last image is a simulation in cimco of the NC generated file to verify that it in fact is incorrect and just not a visual bug in Inventor.
Solved by -niels-. Go to Solution.
Welcome to the forum!
It might be because my system is a little messed up atm, but when i check your model i didn't get any toolpaths.
From the images you posted it looks to me that the backplot isn't showing what you expect...
Might it be possible that the backplot is set to an incorrect postprocessor? (your screen shows "ISO Fräsning")
I'll have to see if i get a moment to go through the tutorial if what i'm saying is totally irrelevant...
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Thanks, my bad, I forgot to save the toolpath...
Re-attaching with it saved!
Niels van der Veer
The Netherlands
This is my result when i change the direction i mentioned:
You are not seeing the same?
It's the only setting i changed, here's another picture for reference:
Niels van der Veer
The Netherlands
No the only change I can see is where the tool starts the workload.
Maybe I have some obscure setting somewhere set differently from yours?
Niels van der Veer
The Netherlands
Niels van der Veer
The Netherlands
Build 246 Inventor Pro 2014 SP2, and my HSM Express version is 1.1.0.125. I got partial success clicking the arrow in choose toolpath mode as you suggested, but it still behaves... unexpectedly:
Installing latest update for HSM Express 2014 now, unless do you think I can run the 2015 version off Inventor 2014?
Edit: the latest update must be installed for 2014 allready in the 2014 SP2 pack, it did not allow me to update or install anything from the HSM Express update package.
Niels van der Veer
The Netherlands
