Inventor Forum
Howto convert Iges file into a solid?
6 REPLIES 6
849 Views, 6 Replies
A supplier has sent me an Iges file which seems to open OK into INV but it
comes in as surfaces only. Is there an easy way to convert these surfaces
into a single solid lump?
Regards
Brian Corbin
Central Construction 1990 Ltd
P.O Box 102
Bluff
Southland
Ph: 03 212 8690
Mob: 021 415 300
Fax: 03 212 8691
6 REPLIES 6
Phil PDX
look for the button under part features that says "promote", if that's greyed out then you have to RMB what ever is in the feature tree below origin folder and say "copy to construction" first, then promote it.
If there are screwed up or missing faces then this might not work so well.
"Brian" wrote in message
news:5407640@discussion.autodesk.com...
Regards
Brian Corbin
P.O Box 102
Bluff
Southland
Ph: 03 212 8690
Mob: 021 415 300
Fax: 03 212 8691
also play with IGES files in their own folder they can be very
dangerous.............see previous posts on IGES files.
nrg_drink
goto autodesklabs, and download the feature recognition lugin, in works with I11
R.Corriveau
Did you get it Brian?
If not maybe you could post it?
Hi Guys,
Sorry bout the time lag 😉
Nope does not seem to want to convert so I am persuming its a shonky iges
file will post it over to CS files as it is 2mb zipped, even though it is a
very simple little assm.
Thanks guys
Regards
Brian Corbin
P.O Box 102
Bluff
Southland
Ph: 03 212 8690
Mob: 021 415 300
Fax: 03 212 8691
wrote in message news:5408000@discussion.autodesk.com...
R.Corriveau
email it to
rickcATorcharddesignusaDOTcom
