Inventor Forum
how would you model this part
14 REPLIES 14
Message 1 of 15
James__S
626 Views, 14 Replies
How would you model this part?
14 REPLIES 14
Message 2 of 15
JoAnn_Hogan
in reply to: James__S
Have a look at something like this?
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
Message 3 of 15
James__S
in reply to: JoAnn_Hogan
Thanks Jo
The shape on your part face is different to the shape on my part face.
Message 4 of 15
JoAnn_Hogan
I see what you mean, Sorry I didn't go back and check yours.
Yours is actually quite nicely done. Why would you want to change it?
Jo - Ann
Message 5 of 15
James__S
Thanks Jo
Wasn`t sure if there was a better way
Thanks again
Message 6 of 15
JoAnn_Hogan
I wouldn't change anything.Good job though
Jo - Ann
Message 7 of 15
mrattray
That's a good looking part. Nothing comes to mind that I would change.
Mike (not Matt) Rattray
Message 8 of 15
graemev
Instead of a split, I would have done a bidirectional extrude-intersection.  It's not specifically "better", just different.
Message 9 of 15
mrattray
in reply to: graemev
Is there actually any reason to avoid the split, though? I've never used a split like this before and I, also, would have used an extrusion, but I can't come up with a good reason why it isn't a valid technique.
Message 10 of 15
graemev
in reply to: mrattray
Sorry, you snuck in before I could post the edit to my reply.  (Went and hit "post" before properly finishing the first time 'round.  D'oh!)
It's not wrong, it's just different.  I am more inclined to use solids and booleans than surfaces when modelling.  This does, of course, impose some limitations on what I can efficiently model, however.  (It's a noted deficiency on my part, really.  PEBCAK: Prioblem Exists Between Chair And Keyboard.)
Message 11 of 15
James__S
Thanks for the responses.How does the bidirectional extrude-intersection work.I have not used before this tool
Thank you
James
Message 12 of 15
JDMather
Delete your Split feature.
Do Extrude and select the circle sketch.
Set to mid-plane through all and instead of Joint or Cut, select the third option - Intersection.
The CADWhisperer YouTube Channel
Message 13 of 15
James__S
in reply to: JDMather
I did do that but i am just curious as to how this feature actually works.I see the final result but how does it work and when best to use
Message 14 of 15
JDMather
A boolean intersection - imagine two solids, your part and the extruded cylinder, only what is common to the space is retained.
I will try find some examples to present where this is useful.
This function might be one of the most neglected, yet useful functions in Inventor.
Message 15 of 15
James__S
Some samples will be appreciated
James
