Hmmm... here's another one. I just finished this part and made the
initial 'lenfrh' extrusion adaptive. Placed it into an assembly and
started to mate it up to other parts. (It's adaptive in the assy too.)
Well, when I constrain it so that it should adapt to the right length,
it just won't adapt. No clue why. I used to adapt, when it was just
flat pieces... but now that I want a mitre relief for my weld joint it
just won't adapt.
I've run into this kind of problem before, things just don't adapt for
some reason. Anyone have any clues for me?
-Jason
Jason M wrote:
> I've got a 20 ft stick of 3/8 in x 5 inch steel flat bar.
> Looking at the 20 ft x 5 inch surface, I want to cut the ends at a 45
> degree angle, but I also want that surface (the cut surface) to be at a
> 45 degree angle.
> How would you model this?
> The way I did it:
> 1. Draw the 3/8 x 5 profile
> 2. Extrude to length
> 3. Sketch 45 cut on top surface
> 4. Negative Extrude to cut it away
> 5. Make work axis on 45 deg edge
> 6. Make work plane thru work axis, specifying 45 degree tilt
> 7. Draw oversized rectangle on work plane
> 8. Negative extrude everything that falls inside rectangle.
> There must be an easier way... I really don't like the drawing an
> oversized rectangle. I'd rather project the edges that I need to, but
> they don't project like a cutting plane, they project like casting a
> shadow.
> TIA,
> -Jason
