Inventor General Discussion
Active Member
niko.jarvinen
Message 1 of 6 (258 Views)
How would I create threads like this
258 Views, 5 Replies
01-06-2013 05:07 AM
I'm trying to learn to use autodesk inventor pro student version by redoing stuff I've been able to find. Currently I'm trying to learn how to create this kind of thread thingy. Any ideas how to start? (this was parasolid cad file originally which I converted)
I've been trying to go around this several ways but can't seem to be able to do it.
Niko
Valued Mentor
Mason-Paul
Message 2 of 6 (248 Views)
Re: How would I create threads like this
01-06-2013 06:38 AM in reply to: niko.jarvinen
First it would be helpful if we knew waht version of inventor you are using.
SO I am asuning you actually want to "cut" this thread.
OK see the 2 attached ipt files on is internal one is external thread, this is a imperial square cut thread but it will give you some idear of how to do this, just open it as normal and have alook.
I'll also post the IDW files for you in another mesage
Inventor 2014 Pro
HP xw8400 workstation
2 x Xeon duel-core 3Ghz CPU , 32 GB Ram
64bit Windows 7 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
Valued Mentor
Mason-Paul
Message 3 of 6 (246 Views)
01-06-2013 06:39 AM in reply to: Mason-Paul
And here are the idw files
Inventor 2014 Pro
64bit Windows 7 Pro
Active Member
niko.jarvinen
Message 4 of 6 (238 Views)
01-06-2013 07:13 AM in reply to: Mason-Paul
Thanks! Didn't even think of using coil + circular pattern. Works like a charm! Thanks for pointing to the right direction.
-Niko
blair
Message 5 of 6 (230 Views)
01-06-2013 08:54 AM in reply to: niko.jarvinen
If it's a single part and the threads are a standard part (listed in the Thread.xls file) and you are on IV2013, install the Thread App and use it to "cut" the threads.
It's the automated way of doing threads on a part, but using the coil-cut method (as posted) teaches you how to do.
IV2015 SP1 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 340.52
SpacePilot Pro 3.17.7, 6.17., 4.11
Delta Tau Chi ΔΤΧ
Active Member
niko.jarvinen
Message 6 of 6 (224 Views)
01-06-2013 09:10 AM in reply to: blair
Thanks but in this case it's far from standard so I'll need to use the coil-cut method.
Niko
