Inventor Forum
How would be the best way to remove this surface
9 REPLIES 9
Message 1 of 10
karthur1
1152 Views, 9 Replies
I am trying to figure out how to remove a portion from this part.  I need the beige colored "lump" removed and it needs to be smooth with the other suffaces.
I can copy the surfaces and then do a patch, but the new surface does not look right.  It has a buldge in it.
Also tried "Delete face" which I use all the time, but it does not work here.
9 REPLIES 9
Message 2 of 10
JDMather
in reply to: karthur1
Check this part.
Message 3 of 10
karthur1
in reply to: JDMather
Yes, Exactly like that.  Can you post the ipt so I can see how you did that?
Kirk A.
Windows 7 x64 -12 GB Ram
Intel i7-930 @ 3.60ghz
nVidia GTS 250 -1GB (Driver 301.42)
INV Pro R2013, SP1.1 (update1)
Vault Basic 2013, SP1
Message 4 of 10
JDMather
I didn't stay in the modeling environment - so there is no full history.
Message 5 of 10
karthur1
Can you explain how you did that?
What did you go to Fusion or something else?
Message 6 of 10
karthur1
JD...
Can you explain how you solved this?
Message 7 of 10
JDMather
I discarded my attempt.
I didn't go to Fusion.
I went back and forth between Construction Environment and Modeling Environment.
Autodesk seems to have Construction, Repair and Inventor conFusion mixed up right now - so I haven't fooled around with this much for the past couple of years, waiting for them to settle out to one environment for editing base solids.
Message 8 of 10
Mark.Downes
Hi Karthur1,
I might be bumping an old post but this might help.
Sometimes surfacing need to be trimmed back to make the topology of the surface easier to match. Loft 1 edge to 1 edge, 2 edges to 2 edges, or as in this case 6 edges to 6 edges etc…). If you keep this in mind most of the time you can get a very quick easy result.
Hope this helps
Cheers
Mark
Inventor 2013
Cheers
Mark
Inventor 2018, 3DS Max 2018, Vault 2018
Message 9 of 10
JDMather
in reply to: Mark.Downes
Very nice solution.
Kind of embarrassed now how much unnecessary effort I expended.
Message 10 of 10
JDMather
This technique (see attached) simplifies to the selection of 5 planar faces.
