how can I copy inventor drawing sheets? I don't want write everything again. It must be a way.
Please help me?
I use inventor 2012.
Autesk inventor product design 2012 Premium.
Solved by CadUser46. Go to Solution.
Start a new drawing file, switch to the file you want to copy the sheet from, then switch to the new file and paste.
... and if you want to copy to the original file, you have to copy to another file first, then copy back to the original from there.
Thanks a lot both of you, but,
I need copied pages in a one "idw".
For example, I make an assembly including 22 parts, and I have to draw 16 parts of 22 parts,
I need 17 sheets in one idw file, because I don't want to write title block inputs again again. I can do multi-sheets with new sheet button, title block is empty.
we can do that mechanical desktop easily...
Thanks for helpings, I wait You!
If you plan on continuing that practise you need to create some custom iproperties in your idw template then create the text parameters inside the title block object. For each new drawing you then fill in your iproperties for that drawing and they will populate each sheet in the drawing.
Thanks I'll try it. I hope it will be solution...
Yes Ok!
Thank You! This was Solution,
Confirmed...
