I made iLogic for assembly and drawing, now i want to update drawing template parameters thru ilogic, as i already linked Fx(parameters) & iProperties to Template, but for updating template i need to close file and open again that file,
currently m using this method.
Please provide soloution for updating drawing template (like Model Description, Drawing no.).
Go to 'Manage' and select 'Event Triggers' under the 'iLogic' Tab. Double click the 'After Save Document' Select your Rule that you have created. Accept your changes and then test it by hitting Save in your drawing.
