Inventor Forum
How to temporarily disable point alignment in sketches
1 REPLY 1
Karol-Or
442 Views, 1 Reply
In application options there is the point alignment option which infers alignment between endpoints of newly created geometry and points of existing geometry.
Is there a shortcut that disbles it temporarilly while sketching?
Is there a list of all the shortcuts?
1 REPLY 1
CCarreiras
in reply to: Karol-Or
Hi!
Yes, you can press "Ctrl" to avoid constraint inferences while you sketching. Release "Ctrl" to continue having inferences.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
