How do I find out what service pack I have installed on Inventor 2011? Where can I go to find out?
Solved by JDMather. Go to Solution.
Help>About Inventor>Product Information
doesn't it just show build numbers these days?
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
I know I have SP1 installed and the Sub pack. But it doesn't state it here:
Scott Moyse
Check in the Windows Control Panel under your Programs and Features, then select the: "View Installed Updates".
Yup I know. But that will help others who don't.
I'm just posting this here to show that for some reason Autodesk has changed this, or its some kind of bug, in response to the original post.
Scott Moyse
only difference so far is mine is 64bit and yours is 32bit. Anyone got a 64bit machine with 2011 they can post a screenshot of?
Scott Moyse
I'm on XP64
Mine also shows 2011 SSR
Check control panel / add remove with update checked
You'll probably see SP1 and Subscription Advantage Pack
SSR is probably "Sub Service Release" or similar
Ok so its a 64bit issue.
Scott Moyse
In your screen shot the build is shown as :
Build 535, Release 2011 SSR - This is because the subscription advantage pack is installed, before the Advantage pack was installed it would have said SP1 and before SP1 was installed it would have said RTM.
Sam B screen shot shows at 2011 SP1, if the above is correct Sam B does not have the subscription advantage pack installed on his machine.
Regards
Martin
You are correct, I do not have the SAP installed.
@Martin_Goodland wrote:... if the above is correct Sam B does not have the subscription advantage pack installed on his machine.
