I'm using Inventor 2013 and when completing one function the system will often/ always auto rotate and zoom. I have no idea what it is trying to do and this is very annoying as well as time consuming to get back to the view I need. Is there a way to turn this off?
Dan,
Inventor can be set to "rotate" when you start a sketch but never seen it do it after.
Like stephen said (assuming you have a 3d controller) have you tried to calibrate it or can you narrow it down as the cause?
