Inventor Forum
How to sketch onto a surface curved in 2 dimensions? [Example shown]
2 REPLIES 2
309 Views, 2 Replies
Lets say I want to make a 3D projection of a cirlce from the face of a mobius strip. I can make the mobius strip, but how do I make a projection from it since at any point. I have a file, and an example I would like to create.
Thanks so much.
2 REPLIES 2
WHolzwarth
Hmm. Your Bend part solution is looking strange. I'm in doubt, if it's ok.
Therefore I tried to use an equation curve. In Wikipedia I found this:
With  0\leq \alpha < 2\pi and -1\leq r \leq 1
Now you can create edge curves for the strip, one with r=-1, the other with r=1. Alpha is changed to t, range between 0° and 360°.
Well, this works ok from 0° to 331°. But what's going on with tmax between 332° and 360°?
😉 Can you hear me, Johnson?
Walter Holzwarth
CCarreiras
Hi!
Nice Challenge!!
Here's my Mobius...
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
