I'll give it a try
Finnur P.
"Sean Dotson" wrote in message
news:62E9A3896AFFC3E52BDC780E12FFCCFE@in.WebX.maYIadrTaRb...
> In addition to Rich's suggestion you might also look at derived parts.
This
> is the process I use to show pre/post machining operations. Make part of
> the unfinished knife then derive the part and add the features to show it
> finished. If you change the basic base part (unfinished) the derived part
> (finished knife) will update to follow the changes.
> Sean Dotson, PE
> http://www.sdotson.com
> ...sleep is for the weak..
> "Finnur P. Frodason" wrote in message
> news:B54323C1CD155BD60F6E5E8A73CD27C8@in.WebX.maYIadrTaRb...
> > How can I show uncut and cut material using the same ipt and/or iam
file.
> > A customer is designing a wheel with some knives. These knives are first
> > laser cut. Then the wheel is assembled and the assembly is turned to
final
> > tolerances.
> > Is it possible to make different views in idw. One view for cut material
> and
> > one view for finished part?
> > Regards
> > Finnur P.
