Inventor General Discussion
New Member
ggautam
Message 1 of 8 (1,854 Views)
how to set up model and paper space
1854 Views, 7 Replies
09-14-2011 06:32 AM
Hi, I am new user of Autodesk inventor but had good experience with AutoCAD. I am trying to draw something of size more than 10 feet in Autodesk inventor (.dwg ) but I cannot set up my space. I can change the size of the sheet. All I can do is to create the custom sheet size of 10' by 10' which is very unelegent way of approaching this problem.
Please suggest.
Thank you in advancce
cbenner
Message 2 of 8 (1,849 Views)
Re: how to set up model and paper space
09-14-2011 06:37 AM in reply to: ggautam
In Inventor you generally set up your sheet size to a standard size (such as a 24 x 36 "D"), and then scale the model appropriately as you place your views on the sheet.  There is no "model space" vs "paper space" like in AutoCad.
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
New Member
ggautam
Message 3 of 8 (1,843 Views)
09-14-2011 06:45 AM in reply to: cbenner
Thanks for the reply. I can right click the sheet name and set the paper size but I cannot find the tab where I can set the scale. I tried right click Sheet:1> Base  View which brings me to the "Drawing View" display box where it seems I can set up the scale. The problem is, I cannot get any further because I cannot get ok button to unfreeze. Can you please explain how to set up the scale for a drawing?
Thank you.
Mike_Maenpaa
Message 4 of 8 (1,822 Views)
09-14-2011 06:59 AM in reply to: ggautam
Thank you.
It sounds like you're trying to do a 2D sketch in the IDW, so that it is scaled to fit on the sheet. Inventor is not AutoCAD
The usual workflow in Inventor is to create a full scale 3D model of your part or assembly and place a Base View at the desired scale on the sheet.
It would be best if you go through the tutorials after pressing the F1 key.
Mike
Distinguished Contributor
msklein
Message 5 of 8 (1,814 Views)
09-14-2011 07:23 AM in reply to: ggautam
I think this might help : IV is not Autocad,  now repeat it.  Honestly  the best thing you can do is forget everything you learned about Acad. They are not the same and the faster you learn the thought process of IV the better off you will be.
 When you place your view on your format pick your scale, its in the lower left hand corner of the dialog box. Also check out the tutorials on line.
msk
JDMather
Message 6 of 8 (1,805 Views)
09-14-2011 07:38 AM in reply to: msklein
Actually all of this works pretty much the same as in AutoCAD, except, you do it more like the real world in Inventor where there are two files. (one for the 3d part - just like the real world, and one for the sheet of paper on which the views representing the 3d part are placed at convenient scale - just like the real world.
So
in Inventor think of your ipt file as model space
and your dwg (or idw) file as paper space.
You place views of your ipt (model space) in your dwg (or idw) paperspace at desired scale.
You can change the scale at any time.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
kstate92
Message 7 of 8 (1,772 Views)
09-14-2011 10:56 AM in reply to: ggautam
If it's long and skinny, with long stretches devoid of details, you could look into adding Breaks to help fit the view(s) onto the drawing.
KState92
Inventor Professional 2014 64 SP2
Windows 7 Pro 64 bit - SP1
Xeon E5-1620
16 GB Ram
Quadro 4000
JDMather
Message 8 of 8 (1,755 Views)
09-14-2011 11:53 AM in reply to: ggautam
I missed this part of your description.
Post your ipt and dwg here and someone will demonstrate how to do Breaks.
