I have generated frame that has 100 members in it. Is there a quicker way of changing G_L unit to a mm so that I don't have to go into all 100 parts to change the custom properties?
also I do not need unit string to be appear in my BOM.
please help
You should be able to change the units here in the tools tab.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Hi Thanks for your quick reply...
this is regarding "parameters custom property format" for more info please see attached images.
