I'm using Inventor 2015. I wonder if is there any way to render Image or Video with Inventor Studio using ray tracking? Standard rendering even on highest settings produces artifically-looking images.
The only way to get ray-traced picture is turning it on in View but its maximum resolution is limited by resolution of viewport. I need a few times higher resolution. Is there any way to make it possible?
to get higher resolution images out when raytracing - when you goto "save copy as" and select an image file type, the "options" button becomes lit. Click this and enter a different resolution. Leaving it as 0,0 you get the screen resolution, but you can specify values for a much larger image.
If you want better quality results than a quicky in Studio then I would highly recommend looking at Showcase. To get good results you almost need to go through the materials again, but once setup it's far easier to get nice results.
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
