Inventor General Discussion
Distinguished Contributor
nstalker
Message 1 of 3 (251 Views)
Accepted Solution
How to remove units from reference parameters
251 Views, 2 Replies
09-26-2013 07:02 AM
I named a driven dimension parameter so I can reference it elsewhere in my model.  The problem is that the driven dimension is in inches and the reference parameter does not allow me to change the units.  I would like to use that driven dimension in my model and divide it by the pitch in a pattern to get the correct count for my pattern.  The pattern dialog box is expecting a unitless input.
I tried creating a unitless user parameter that referenced the reference parameter but that did not work.
Hi!
Now You have a parameter let's call him "driven", unit: "in"
Now, create a new numeric parameter, choose "ul" as unit
We will call this parameter as: "driven_converted"
To convert use this expression:
Now you can use this "Driven_converted" to use in other parameters.
Remember that:  if you want to use this parameter as a array qty, you will need a integer, maybe you have to add another prefix:
floor(expr) -------- unitless (Next lowest whole number.)                             ex: 2.8 - > 2
ceil(expr)  --------- unitless (Next highest whole number.)                           ex: 2.8 - > 3
round(expr) -------unitless (Closest whole number.)                                    ex: 2.3 - > 2            2.6 - > 3
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
nstalker
Message 2 of 3 (243 Views)
Re: How to remove units from reference parameters
09-26-2013 07:19 AM in reply to: nstalker
Found the answer here
http://forums.autodesk.com/t5/Autodesk-Inventor/Floor-or-Ceil-value-from-reference-parameter/td-p/59...
looks something like this
isolate(referenceparameter;unit;ul)
Distinguished Mentor
ccarreiras
Message 3 of 3 (235 Views)
09-26-2013 07:48 AM in reply to: nstalker
Hi!
Regards.
CarlosC
Autodesk Inventor 2014 Certified Professional
Autodesk Factory Design Suite Ultimate 2015
Windows 7 64Bit
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
