Inventor General Discussion
Distinguished Contributor
nstalker
Message 1 of 3 (228 Views)
How to remove units from reference parameters
228 Views, 2 Replies
09-26-2013 07:02 AM
I named a driven dimension parameter so I can reference it elsewhere in my model.  The problem is that the driven dimension is in inches and the reference parameter does not allow me to change the units.  I would like to use that driven dimension in my model and divide it by the pitch in a pattern to get the correct count for my pattern.  The pattern dialog box is expecting a unitless input.
I tried creating a unitless user parameter that referenced the reference parameter but that did not work.
nstalker
Message 2 of 3 (220 Views)
Re: How to remove units from reference parameters
09-26-2013 07:19 AM in reply to: nstalker
Found the answer here
http://forums.autodesk.com/t5/Autodesk-Inventor/Floor-or-Ceil-value-from-reference-parameter/td-p/59...
looks something like this
isolate(referenceparameter;unit;ul)
Distinguished Mentor
ccarreiras
Message 3 of 3 (212 Views)
09-26-2013 07:48 AM in reply to: nstalker
Hi!
Now You have a parameter let's call him "driven", unit: "in"
Now, create a new numeric parameter, choose "ul" as unit
We will call this parameter as: "driven_converted"
To convert use this expression:
Now you can use this "Driven_converted" to use in other parameters.
Remember that:  if you want to use this parameter as a array qty, you will need a integer, maybe you have to add another prefix:
floor(expr) -------- unitless (Next lowest whole number.)                             ex: 2.8 - > 2
ceil(expr)  --------- unitless (Next highest whole number.)                           ex: 2.8 - > 3
round(expr) -------unitless (Closest whole number.)                                    ex: 2.3 - > 2            2.6 - > 3
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
Regards.
CarlosC
Autodesk Inventor 2014 Certified Professional
Autodesk Factory Design Suite Ultimate 2015
Windows 7 64Bit
