Inventor Forum
Welcome to Autodeskā€™s Inventor Forums. Share your knowledge, ask questions, and explore popular Inventor topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
How to remove student version content center?
8 REPLIES 8
Message 1 of 9
haridraf
939 Views, 8 Replies
Hi! I installed AutoCAD Inventor Professional Suite 2011. I have a problem with its content center. When ever content center is used, student version banner comes on my 2D projected drawings. This makes my drawings worthless. How can I remove this student version banner?
Thanks in advance for your support.
Haridra
8 REPLIES 8
Message 2 of 9
blair
in reply to: haridraf
Un-install the existing Content Center, delete all remaining directories. Re-install CC from the Commercial version source media.
Any parts that were created with the Student version will produce the banner on your drawings as well. It could be a single IPT in a 10,000 part assembly.
There was a fix, utility a while back that would go through your IPT's and strip out the "Student Version" data. You may have to check with your Reseller or submit a subscription request with Autodesk Support.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi Ī”Ī¤Ī§
Message 3 of 9
haridraf
in reply to: blair
Thanks Blair.
Does anybody know how to buy the fix utility.
Message 4 of 9
haridraf
How do I remove content center?
Message 5 of 9
haridraf
in reply to: blair
I am having trouble in un-installing the current Content Centre. Could somebody help me pl, how do I do it?
Message 6 of 9
blair
Try using the Install Media, then select what you want to Un-Install (de-select).
Message 7 of 9
haridraf
I used Windows Clean up and remove the content center. Although it dose not appear under progarms any more, it still appears in the Inventor 2011. How do I access Install Media? Thanks.
Message 8 of 9
blair
You should have the install discs/USB thumb-drive when you purchased your copy of Inventor.
Message 9 of 9
blair
Any part created by your Student Version will produce this banner. Try creating new CC part and place it into a IDW and see if you get the banner.
Something tells me, that you have some parts (IPT's) that you are using in your IAM's that were created using a Student Version.
These could be CC items or non-CC IPT's. All it takes is a single IPT to cause the banner to be displayed.
