how do i remove the material from beneath the Green line (3D sketch 1).I want to remove material to Extrusion 1..thanks
Invento 2014
Solved by wimann. Go to Solution.
You can do a sweep cut with surface guide type.
If you want to do it only for extrusion 1 you can considerate to model a multibody.
Admaiora
I don't know your design intent.
Attached an example of sweep along surface
Admaiora
This is the shape but i am sure it can be done much better.I created the shape to show what i want to model.Also i cannot fillet along the sharp edge.How should i have made this?
I have to say that you would have been better off either backtracking (moving the "End of Part" up in your browser) until you could make the change early so as to not affect other things, or a multibody part for that matter. But if you had to do it from this point, what I would say is to use the "Sketch6" you had before and complete it as I have attached. Then make an extrusion off of the upper profile to the flat face of the piece (effectively cutting extrusion 1) see attached. Then extrude the Lower profile to the curved surface on the underside of the part (see attached). Then Mirror your new features over the YZ Plane and you're done!
The .ipt from my response before is attached.
Hi! Have you tried Multi-Solid workflows? You could make the rest of Extrusions seperate solids. So they don't participate in the same feature operation. To cut along the 3D Sketch, I think you can use Sketch6 by creating a surface or a closed profile. I don't see a need to use 3D Sketch in this particular case.
Thanks!
