Inventor General Discussion
Distinguished Contributor
barnadaniel
Message 1 of 10 (1,260 Views)
How to remove a hole from a set of holes
1260 Views, 9 Replies
08-06-2010 08:34 AM
I have edited an associative part within an assembly. Created a sketch on one of the surfaces, and projected the surface of another part, which had holes. Then created a set of holes, by selecting some of the hole centers from this projected sketch. Later I wanted to remove one of these holes, but it doesn't seem to be possible. I can not de-select a point. Is this possible somehow?
Inventor 2011
This is a stinking bug in 2011.  In order to remove the hole, you have to stop what you are doing, and make the sketch visible.  Then you have to edit the feature and while holding down shift and remove the point from the selection set.
Now you have to turn the sketch back off.
Real PITA.  Hoepfully it will get fixed with 2012.
mcgyvr
Message 2 of 10 (1,256 Views)
Re: How to remove a hole from a set of holes
08-06-2010 08:56 AM in reply to: barnadaniel
I'm not positive but I believe this was a bug reported a while ago that never got fixed.. You can simply fill the hole with another sketch/extrusion as a workaround.
There was another post about this but I can't seem to find it now
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
JDMather
Message 3 of 10 (1,248 Views)
08-06-2010 09:27 AM in reply to: barnadaniel
barnadaniel wrote:
... by selecting some of the hole centers from this projected sketch. Later I wanted to remove one of these holes, but it doesn't seem to be possible. I can not de-select a point.
Inventor 2011
I assume you are holding the Ctrl key when trying to deselect?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
karthur1
Message 4 of 10 (1,237 Views)
08-06-2010 10:39 AM in reply to: barnadaniel
Employee
johnsonshiue
Message 5 of 10 (1,208 Views)
08-06-2010 01:35 PM in reply to: karthur1
Kirk,
This issue has been corrected on an internal build. It should be available in an update.
barnadaniel,
Is the issue you are talking about the same as Kirk's? If not, please let me know the steps to reproduce. I am a bit confused about how to reproduce the problem.
Thanks!
Senior Principal SQA Engineer, Inventor
Mechanical Design
barnadaniel
Message 6 of 10 (1,155 Views)
08-09-2010 01:54 AM in reply to: karthur1
Thanks a lot!
Member
CArceneaux
Message 7 of 10 (633 Views)
06-14-2012 03:29 PM in reply to: johnsonshiue
Johnson,
I'm experiencing the same situation in 2012 with the inability to edit a hole feature and deselect hole centers. This is not an adaptive sketch as in the OP and I've tried making the sketch visible. Have also tried toggling hole terminations and direction which was successful in another part.
Recreating the feature makes for correcting dimensions, constraints, and hole tables.
Any help that you could provide would be greatly appreciated,
Chad
Employee
johnsonshiue
Message 8 of 10 (623 Views)
06-14-2012 04:02 PM in reply to: CArceneaux
Hi! If you could post the file here or send it to me, I would take a look and see where the problem is.
Thanks!
Mechanical Design
Member
CArceneaux
Message 9 of 10 (587 Views)
06-18-2012 06:49 AM in reply to: johnsonshiue
Johnson,
I sent the file and appreciate you looking into this.
Thank you!
Product Support
bobvdd
Message 10 of 10 (560 Views)
06-18-2012 02:27 PM in reply to: CArceneaux
Johnson and myself looked into this and we have logged it as defect
1464663 Cannot deselect center points from existing hole
Bob
