Inventor General Discussion
Active Member
prixodkomv
Message 1 of 2 (466 Views)
How to read file properties Inventor (ipt. idw. dwg) of a web application.
466 Views, 1 Replies
04-03-2013 12:49 PM
Hello I am developing a web app ASP.NET MVC 3, which will read the properties files of Inventor (dwg, idw, ipt, iam). Read the properties of these files is by using objects Apprentice Server, which provides Autodesk Inventor View 2012. Connection objects is done through the library RxApprentice.tlb.
Code is shown below:
 public ActionResult Index ()
       try
           ApprenticeServerComponent appServerComponent = new ApprenticeServerComponent ();
           ApprenticeServerDocument apprenticeServerDocument = appServerComponent.Open (FileName);
           var ListPropety = apprenticeServerDocument.PropertySets ["Design Tracking Properties"].
        Cast <Property> (). ToList ();
           var CollectionProperty = ListPropety
                                . Where (x => x.Name! = "Thumbnail")
                                . ToDictionary <Property, string, object> (
                                    property => property.Name,
                                    property => property.Value
                ViewBag.CollectonProperty = CollectionProperty;
                catch (System.Runtime.InteropServices.COMException ex)
                    ViewBag.ComException = ex.Message;
            return View ();
While debugging applications on Web-server - IIS Express 7.5 development environment Visual Studio 2010 application runs without errors.
After publishing a Web application on IIS 7.0 the following error: "Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))».
A tried: change User Account Control Settings, and set permissions to configuration DCOM objects in Component Services  - no results.
Is it possible to read the file properties Inventor of Web applications, and how to do it? Help solve the problem. Thanks for any help!
Curtis_Waguespack
Message 2 of 2 (464 Views)
Re: How to read file properties Inventor (ipt. idw. dwg) of a web application.
04-03-2013 12:51 PM in reply to: prixodkomv
Hi prixodkomv,
You might have better luck asking questions and searching for answers of this type on the Inventor Customization forum:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
