I have created a loft from 4 different sketches. Now I want to make a drawing with the front, side view and the dimensions of the 4 profile sketches from the loft. But I can’t find a way to put the sketches from the part on my paper. It works with copy-paste ;^) but this is not the way I want it (it’ll not change when I change the profiles in the part).
Thank you for the reply
I try it but it only shows the sketch that is planar to the view.
I can't see the profiel sketches.
(ipt) I changed my model so it uses sketchblocks but I'm not sure how to put them on my paper.
(ipt) I used the export function in the blocks section of the part.
(idw) I made a draft view but there is no way to import the sketchblock in the sketch of the draft view.
I don't know what you mean with layout?
Thank you for the reply, I'm learning every day.
