Inventor General Discussion
Distinguished Contributor
5 Kudos
Post 1 of 5
How to position, precisely, the key with the Key Generator?
306 Views, 4 Replies
12-13-2012 11:32 AM
I use the Key Generator from the Design Accelerator and drag the red arrow to position the key under the gear.
Numbers change, and when i position the key they disappear.
There is no way to input a precise dimension. am i right?
Find the key in the model browser, click on its flush constraint, and change its value.  Is that what you're trying to do?
Also, if you're tying to rotate the keyway, you can accomplish this at the part level with the "Move Face" command, set to "Free Move." Then select "Reposition Triad," move it to a point at the center of rotation, and you can rotate the keyway to a precise angle.  This method still allows you to edit the keyway from the design accelerator, too.
229 Kudos
Post 2 of 5
Re: How to position, precisely, the key with the Key Generator?
12-13-2012 12:24 PM in reply to: Karol-Or
The only way I have seen to position it precisly is to dig into the part the Keyway was created in and Explode the Accelerator feature so you can modify the iFeature by itself.  The problem with this is that once you do this the Edit Keyway in the Assembly becomes broken.  Still not a bad way to get the features down to the part tree.
Mark Flayler - Senior Application Engineer
IMAGINiT's Manufacturing Solutions Blog:
http://blogs.rand.com/manufacturing/
5 Kudos
Post 3 of 5
12-13-2012 12:54 PM in reply to: Mark_Flayler
Where is the command to explode the Keyway?
I right clicked the Key Connection, didn't find
Valued Contributor
10 Kudos
Post 4 of 5
12-13-2012 01:45 PM in reply to: Karol-Or
-Using Autodesk Inventor Professional 2012
229 Kudos
Post 5 of 5
12-13-2012 01:58 PM in reply to: nannerdw
Silly me, overthinking the obvious on that one.
Yes, just expand the Key Connection in the browser and adjust the constraint values, the iFeatures in the parts will follow suit.
