When I try to scale a part in Autodesk Inventor Fusion, it asks to select a solid body, and reference point, but there is no option to change the scaling type to nonuniform. Can anyone walk me through how to do it? I have Autodesk Inventor and Autodesk Inventor Fusion 2013. Thanks!
This question has come up here many times in the past - search on SDK and non-uniform scale.
There is a tool in the SDK.
The most relevant thread about this topic is at http://forums.autodesk.com/t5/Autodesk-Inventor/Scale-a-part-with-different-scale-factors-in-3-direc.... However a solution was never found. I've installed usertools, and DerivedPart_SP is in that folder. However, the add on is not appearing in Inventor...
