Using IV 2009 FEA:
1. make a free body diagram of the container and calculate the resultant forces in the rigging. Resolve them to x,y,z components using the same coordinate system as the container model.
2. make a surface(s) on the inside of the container to represent the location and size of the equipment in the container. use the split command.
3. make a surface on the pad eye to represent the area that the rigging hook touches the pad eye.
4. go into the fea tool and apply a fixed constraint to one of the equipment surfaces. apply a frictionless constraint to the other
5. apply the loads that you calculated in the free body diagram to each pad eye. Use the vector mode to enter the x,y,z components of the forces.
If your model is big, consider using symmetry to simplify it and cut it in half or quarters.
Steve Walton
Inventor 2023
Vault Professional 2023
