I have 2 piping runs, each one containing several routes. I need to merge them, to obtain a unique run containing all the routes. Is it possible ?
The short answer is no. Each pipe route is essentially a separate sub-assembly within your main assembly. Unless there are some tricks I don't know about, I think your best bet is to pick whichever of the two was the most complex, delete the other one, and add to the first one.
Sorry... not the answer you wanted I'm sure. I'm hoping that there is some trick I haven't heard of yet and that someone else comes forward with a different response... this would be helpful to me as well.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I dreaded this answer... I tried to copy/paste, promote, move, make adaptative,... nothing ! If someone have an idea...
