Inventor General Discussion
Distinguished Contributor
4 Kudos
Post 1 of 4
How to match color print quality with in-canvas lighting settings?
203 Views, 3 Replies
11-13-2012 06:38 PM
Is there a way to control color print quality that matches the in-canvas look of a part or assembly.
As a quick example, I have a Kelly Green wire visible within an assembly.  When I print the assembly within a .idw drawing file, the Kelly Green turns very dark.
Is it possible to specify a particular lighting setting to be used when printing?
I'm expecting to see color print output that matches closely to what I see when viewing either a model or an assembly.
I'm using Inventor 2013.
Thank you in advance for your assistance in this matter!
Jim Strenk
Inventor 2012 Certified Associate
AutoCAD 2012 Certified Associate
Product Design Suite Ultimate 2012, 2013, 2014 & 2015
Other than THAT, Mrs. Lincoln, how was the play??
Illinois: Where we send more Govenors to prison, than on to retirement!
774 Kudos
Post 2 of 4
Re: How to match color print quality with in-canvas lighting settings?
11-13-2012 07:38 PM in reply to: JimStrenk
It is controlled within the Appearance>Settings: for the "Two Lights". Sometime the items are within the "shadow" and appear darker because of this.
IV2015 SP1-ud2 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-980 Classified - 347.09
SpacePilot Pro 10.2.0 / 17.2.0.11011 / 4.17
Delta Tau Chi ΔΤΧ
4 Kudos
Post 3 of 4
11-13-2012 07:48 PM in reply to: blair
Thanks Blair for the reply!
I'm not at a machine right now.  Is it possible to change the lighting settings to some other value prior to printing?
Jim Strenk
774 Kudos
Post 4 of 4
11-13-2012 09:16 PM in reply to: JimStrenk
Not prior to printing, the color view in the Iso view comes from the two-light setting from the modeling environment. It may require creating a new lighting style depending on the angles of the lights and the position of the components within the model.
Win7-64
Delta Tau Chi ΔΤΧ
