Inventor Forum
How to make single surface of part transparent so inside of part is visible?
12 REPLIES 12
Message 1 of 13
hhls11
10830 Views, 12 Replies
I'm modeling a temperature gauge and would like to have glass over the gauge so the inside is visible. I can easily do this with an assembly, but I'm wanting to do this with a single part. I tried to derive a new part from the assembly, but the transparent part turns solid so nothing inside is visible. Is it possible to do this?
I've include pictures of what I want and what I end up with. Thanks in advance!
Inventor Professional 2021
Intel Core i7-9700K @ 3.60Ghz
16GB DDR4 RAM
NVIDIA GeForce RTX 2060 Super GPU
Windows 10 Professional 64-bit
12 REPLIES 12
Message 2 of 13
yannick3
in reply to: hhls11
Hi
The transparent texture cannot be apply to single body in multibody part
This is limitation
Yannick Verreault
INV PRO 2015
MS Office 2007
Win 7 pro, core i7 950, asus P6T WS
nvidia Gforce GTX 295
WD caviar black 500Go
WD caviar black 1To
Message 3 of 13
rdyson
in reply to: yannick3
@Anonymous wrote:
Hi
This is limitation
I've just tried this twice. The first time it didn't work, the second it did. I don't know what the difference is.
PDSU 2016
Message 4 of 13
johnsonshiue
in reply to: hhls11
Hi! The transparent color cannot be applied to Features or Faces on a given solid body. It is because exposing the back faces of non-transparent surfaces would make the view very confusing to look at. You can create a separate body just for the glass piece and make it transparent in the part
Thanks!
Software Test Engineer
Message 5 of 13
in reply to: johnsonshiue
You have to create a new seperate body to do this, just like rdyson showed in his picture.
Message 6 of 13
mpatchus
A seperate solid for the glass works fine.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Message 7 of 13
yannick3
in reply to: hhls11
Hi
 sorry for the bad information
i would it mean that's for feature like Johnson point
Yannick Verreault
INV PRO 2015
MS Office 2007
WD caviar black 1To
Message 8 of 13
Just make sure as you extrude the bodies in a multibody part to select the new body selection button (highlighted).
Then select the solid body in the browser and apply color to it, or in your case glass material.
Message 9 of 13
I cannot seem to get just one extrusion to be transparent in my model.  Can you help?  I would like just the body (extrusion 4) to betransparent.
dwing
Message 10 of 13
JDMather
You need to create as multi-body solid as already discussed in this thread.  See response #8.
Your sketches aren't constrained (yet a perfect dimensions if I add them - did you delete them, if so why)?
Workplane1 is not needed.
I recommend you start here http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Message 11 of 13
in reply to: JDMather
Thanks for the quick reply J. D.
The model I have was originally a Pro/E .step file.  I used Inventor Feature Recognizer to create the .ipt, that is why the sketches are not constrained.
It seems like I would have to re-create the model from scratch in order to 'do it correctly'.  Thanks anyway.
dwing
Product Designer
Young & Franklin, Inc.
Specialty Fluid Controls
www.yf.com
Message 12 of 13
JDMather
You have the sketches - so you wouldn't need to completely start from scratch.
Simply change the Extrusions to New Solid.
Message 13 of 13
OK, J. D. thanks again.  What I didn't catch on to is that once the Extrusions are set to be New Solids, you have to edit the Solid's properites, NOT the individual extrusions. (I think.)
So, I set the Extrusion property to "As Body" and the corresponding Solid to the appearance I wanted. (Although it seemed like I had to try a whole bunch of times before it 'magically' worked.  Even then I'm not really sure that what i did.)
Thanks again for your help, and I hope this thread helps others.
dwing.
Product designer
Young&Franklin, Inc,
www.yf.com
