Inventor Forum
How to make single surface of part transparent so inside of part is visible?
12 REPLIES 12
Message 1 of 13
hhls11
10822 Views, 12 Replies
I'm modeling a temperature gauge and would like to have glass over the gauge so the inside is visible. I can easily do this with an assembly, but I'm wanting to do this with a single part. I tried to derive a new part from the assembly, but the transparent part turns solid so nothing inside is visible. Is it possible to do this?
I've include pictures of what I want and what I end up with. Thanks in advance!
Inventor Professional 2021
Intel Core i7-9700K @ 3.60Ghz
16GB DDR4 RAM
NVIDIA GeForce RTX 2060 Super GPU
Windows 10 Professional 64-bit
12 REPLIES 12
Message 2 of 13
yannick3
in reply to: hhls11
Hi
The transparent texture cannot be apply to single body in multibody part
This is limitation
Yannick Verreault
INV PRO 2015
MS Office 2007
Win 7 pro, core i7 950, asus P6T WS
nvidia Gforce GTX 295
WD caviar black 500Go
WD caviar black 1To
Message 3 of 13
rdyson
in reply to: yannick3
@Anonymous wrote:
Hi
This is limitation
I've just tried this twice. The first time it didn't work, the second it did. I don't know what the difference is.
PDSU 2016
Message 4 of 13
johnsonshiue
in reply to: hhls11
Hi! The transparent color cannot be applied to Features or Faces on a given solid body. It is because exposing the back faces of non-transparent surfaces would make the view very confusing to look at. You can create a separate body just for the glass piece and make it transparent in the part
Thanks!
Software Test Engineer
Message 5 of 13
Leanderjk
in reply to: johnsonshiue
You have to create a new seperate body to do this, just like rdyson showed in his picture.
Regards, Leander
Work: Autodesk Inventor 2010
Home: Autodesk Inventor 2013
Message 6 of 13
mpatchus
in reply to: Leanderjk
A seperate solid for the glass works fine.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Message 7 of 13
yannick3
in reply to: hhls11
Hi
 sorry for the bad information
i would it mean that's for feature like Johnson point
Yannick Verreault
INV PRO 2015
MS Office 2007
WD caviar black 1To
Message 8 of 13
swhite
Just make sure as you extrude the bodies in a multibody part to select the new body selection button (highlighted).
Then select the solid body in the browser and apply color to it, or in your case glass material.
Steven White
Lee C. Moore, Inc.
www.lcm-wci.com
Inventor 2011
Intel Dual Xeon E31225 @ 3.1 GHz CPU
16 GB RAM
NVIDIA Quadro 600 GPU
Windows 7 - 64 Bit
Message 9 of 13
dwing
in reply to: swhite
I cannot seem to get just one extrusion to be transparent in my model.  Can you help?  I would like just the body (extrusion 4) to betransparent.
dwing
Message 10 of 13
JDMather
in reply to: dwing
You need to create as multi-body solid as already discussed in this thread.  See response #8.
Your sketches aren't constrained (yet a perfect dimensions if I add them - did you delete them, if so why)?
Workplane1 is not needed.
I recommend you start here http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Message 11 of 13
dwing
in reply to: JDMather
Thanks for the quick reply J. D.
The model I have was originally a Pro/E .step file.  I used Inventor Feature Recognizer to create the .ipt, that is why the sketches are not constrained.
It seems like I would have to re-create the model from scratch in order to 'do it correctly'.  Thanks anyway.
dwing
Product Designer
Young & Franklin, Inc.
Specialty Fluid Controls
www.yf.com
Message 12 of 13
JDMather
in reply to: dwing
You have the sketches - so you wouldn't need to completely start from scratch.
Simply change the Extrusions to New Solid.
Message 13 of 13
dwing
in reply to: dwing
OK, J. D. thanks again.  What I didn't catch on to is that once the Extrusions are set to be New Solids, you have to edit the Solid's properites, NOT the individual extrusions. (I think.)
So, I set the Extrusion property to "As Body" and the corresponding Solid to the appearance I wanted. (Although it seemed like I had to try a whole bunch of times before it 'magically' worked.  Even then I'm not really sure that what i did.)
Thanks again for your help, and I hope this thread helps others.
dwing.
Product designer
Young&Franklin, Inc,
www.yf.com
