I have a part that is shaped like the attached. How to make a marking emboss on the red area?
Because before make a emboss i can't make sketch in area that.
thanks before...
Solved by SBix26. Go to Solution.
Sketch1 is not constrained or making use of obvious symmetry about the origin.
I recommend you start here http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Then you will want to make a plane tangent to your conical face for sketching the 2D to Emboss with Wrap to Face.
First, do what JDMather recommends above. Then open the part I have attached, pull the End of Part marker down and examine how I did it. This is not the only way, nor the "right" way, but it is robust and relatively easy to modify as needed. Notice in sketch 1 that I did not need to divide all my diameter dimensions by two, but instead turned the axis to centerline type. Dimensions placed to a centerline will automatically be placed as diameter dimensions. I also used the Split tool with Trim Solid selected rather than the Sculpt tool. Both tools give the correct result, but the Split tool is a bit more obvious to someone else looking at the file.
If you run into difficulties, post back here with your model attached.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 2
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
SpaceExplorer/SpaceNavigator NB, driver 3.16.2
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
sorry i did not understand the tutorial. tutorial number how much should I use? could be more specific step by step.
Sketch2 contains the line where the angled face intersects the XY plane. To create the tangent work plane, I selected the XY plane and the sketch line and left the default angle of 90°. That is: Work Plane tool > select XY plane > select sketch line in Sketch2 > OK (to accept angle dimension 90°).
Sam B
