Inventor Forum
how to make (*.ide)
2 REPLIES 2
admin
2424 Views, 2 Replies
how to make (*.ide)
dear sir, i have face a problem while doing punch tool operation please suggest me how to do?
regards
santosh
Tags (1)
2 REPLIES 2
in reply to: admin
You need to extract a sketch to make an iFeature.  I am not sure what you did judging by your jpg, but you definitely did not extract a sketch.  The iFeature needs to begin with a center point, and then base your sketch(es) from that.  Then cut or extrude.  After that, look for the "extract iFeature" function
Good luck!
Yong.Jing
in reply to: admin
From the screenshot, it sound there is no right to publish iFeature into the Content Center Library.
So go to Application Options->Center Center.
At here, check the Access Options. You might use Vault Sever.
Secondly, back to the project dialog box, check the Configure Center Center Libraries, check you have access and modify right to the center center libraries.
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
