Inventor General Discussion
0 Kudos
Post 1 of 3
how to make (*.ide)
661 Views, 2 Replies
11-23-2012 03:58 AM
dear sir, i have face a problem while doing punch tool operation please suggest me how to do?
regards
santosh
New Member
0 Kudos
Post 2 of 3
Re: how to make (*.ide)
11-24-2012 08:32 PM in reply to: admin
You need to extract a sketch to make an iFeature.  I am not sure what you did judging by your jpg, but you definitely did not extract a sketch.  The iFeature needs to begin with a center point, and then base your sketch(es) from that.  Then cut or extrude.  After that, look for the "extract iFeature" function
Good luck!
Product Support
5 Kudos
Post 3 of 3
11-25-2012 08:04 PM in reply to: admin
From the screenshot, it sound there is no right to publish iFeature into the Content Center Library.
So go to Application Options->Center Center.
At here, check the Access Options. You might use Vault Sever.
Secondly, back to the project dialog box, check the Configure Center Center Libraries, check you have access and modify right to the center center libraries.
Yong Jing
Product Support Specialist
Frontline Technical Support, CSS. GCSO
