Inventor Forum
How to make fan blades & Propellers?
2 REPLIES 2
4129 Views, 2 Replies
I'd like to know what steps are need to create fan blades and propellers.
I anticipate making a two-blade propeller for an aircraft and fan blades
found in a computer case exhaust fan.
Any tips, suggestions or errata would be deeply appreciated!
2 REPLIES 2
The only way to do it in IV is to use a loft either several crossections or
2 sketches and several guide rails. You still don't have a lot of control.
How accurate would you need it? If you have surface data from another
program you can import that as construction data and use them as
trim/extrude to surfaces.
Pat
"Jim Strenk" wrote in message
news:6DF720F699630A4B369BCEE4B13EB423@in.WebX.maYIadrTaRb...
There is a fan iPart on Kent's website
(http://www.mymcad.com/kwik/iparts/iparts.htm). That example will give
you a start on the computer fan.
Hal Gwin
Mechanical Designer
Xenogen
W2K SP4
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
nVidia 6.14.10.4472 w/registry update
Dell UltraSharp 19" LCD
