I'm using Inventor 2013, and try to build a simple sheet metal frame chassis (picture attached)
I modelled each part individually, including the miter joint for part 1 & 2 (using the corner chamfer on each part).
But when I tried to assembly this 2 parts, part interference occured (on the miter joint area).
To overcome this problem I have to modify each corner chamfer (sort of trial and error) to make part 1 & 2 perfectly assembled.
I'm looking for the best way to:
- make this assembly and,
- make the miter join for part 1 & 2 in the assembly (rather than make corner chamfer on each part).
Please advise me what is the best method to make this assembly and mitter joining part 1 & 2 in assembly.
Thank you.
Either use Frame Generator
or
multi-body solids technique. No need for trial and error - trivially easy.
Attach your assembly here if you can't figure it out.
As indicated above -
Will you be bending the sheet metal - or purchasing off-the-shelf.
Hi!
Check the video about frame generator...
https://screencast.autodesk.com/Embed/Timeline/d8cd6a43-2e75-4e4b-beef-2b0ffa975bea
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
Hi engkube,
As JDMather mentioned, if you're making the sheet metal parts and therefore need a flatpattern from them, then the Frame Generator might not give what you need, at least not out of the box.
But you could use Frame Generator with a custom profile as shown in this video:
https://www.youtube.com/watch?v=1Ff9yIVNAa4
Likewise you could create the legs of the frame in a single part file with multiple solid bodies as shown in the attached part file, and then use the Make Components tool, to write out each solid as a separate part in an assembly file.
https://www.youtube.com/watch?v=iDRotf2Is2g
I hope this helps.
Curtis
