Inventor Forum
How to make baseline dimensions on one line
2 REPLIES 2
Karol-Or
1663 Views, 2 Replies
Like in the picture, and what is the name, if exists, to such dimensions
2 REPLIES 2
CCarreiras
in reply to: Karol-Or
Hi!
You can do it manually.
First create a baseline dimension (not Baseline Set), and then, drag each dimension to the same lineline.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Cadmanto
Once you have all of your dimensions created, tag them all (holding down the Ctrl key) and RC and select as shown below.  This will snapp them all in line with each other.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-happy:
Best Regards,
Scott McFadden
(Colossians 3:23-25)
