Inventor Forum
How to make a wire
6 REPLIES 6
3304 Views, 6 Replies
How to make a wire
How can i make a wire to connect other parts. Possibly bendable in assembly???
6 REPLIES 6
JDMather
It depends.
What version of Inventor are you using?
Inventor 10 Pro
mcgyvr
make sure you have electrical pins placed on your connectors
(done in the part environment, switch the harness mode and add the pin)
Then create a wire harness in the assembly environment.
You need to read the book "routed systems" that comes with the program. try the tuturials,etc...
The basic premise used in routing tubes and wiring in IV-Pro is essentially
the same as what you would use in regular IV. It's essentially just
creating a path with a 3d spline and using that for a sweep. You can make
the wire somewhat bendable in an assembly by choosing fit points in the
spline that are constrained to moving pieces of geometry. This makes the
spline adaptive.
It's been a while, but IIRC, the tubing module gives you the option to fix
the spline length which makes the adaptive motion a bit more realistic. A
normal 3d spline will stretch when deformed.
Patrick
mcgyvr
patrick, he has INV10 PRO, the wire harness module does not require you to do a 3d sweep, only define the end points of the wire by clicking on electrical pins placed in the connectors part environment. Then by adding points to the actual wire you can define its location/bends,etc...
He needs to read the routing system's book for the cable and harness section and use that functionality.
Yeah, I know. I was just trying to clarify how Pro works, that the wire
path is essentially the same as a 3d spline. An adaptive wire can be done
using regular IV series, Pro just automates the process.
Patrick
wrote in message news:5177781@discussion.autodesk.com...
