Inventor Forum
How to make a spring move
23 REPLIES 23
Message 1 of 24
curt.darius
2394 Views, 23 Replies
Hello everybody, I'm doing a project for school and I built a shock absorber. I've already done about 50% of the project, but I'm havin a problem with the spring, I can't make it move. And I don't want to use any animations, I want to be able to move the part manually. Also there is a preload force applying on the spring, so I have to move (preload) it for x mm to the left. How do I do that? I've attached a photo and the project files for you to understand what I need.
1. How do I make the spring moveable
2. How do I set an offset between the 2 plates, for the spring to be preloaded
Open "forum" file from the project folder to see the part.
Project files
Thank you.
23 REPLIES 23
Message 21 of 24
CCarreiras
in reply to: curt.darius
Hi!!
I will make your spring in Inv 2014 and i will sent you, ok?
I think it is a very complcated to explain you how to do it... it's better you explore the parts.
See you soon...
CCarreiras
Message 22 of 24
curt.darius
in reply to: CCarreiras
Ok, thank you very much.
Message 23 of 24
CCarreiras
HI!!
Here's the assembly.
Open in Inv 2014.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Message 24 of 24
CCarreiras
HI!
https://screencast.autodesk.com/Embed/Timeline/d6b1add8-e775-4394-921b-1054b8fb71ab
CCarreiras
