Inventor Forum
How to make a solid object from a 3d sketch?
8 REPLIES 8
Message 1 of 9
robm1983
2177 Views, 8 Replies
Hello gentelmen,
I was woundering that might be the best way to make a solid object from such 3d sketch? Please see the attached file.
8 REPLIES 8
Message 2 of 9
JDMather
in reply to: robm1983
I don't see any 3D geometry - so first of all, I would have used 2D sketches.
I see geometry that I would expect to be Construction linetype as Normal linetype.
While I take a closer look, have you installed Service Pack 2 for r2014?
Message 3 of 9
robm1983
in reply to: JDMather
there are two 2d sketched aswell. but how should I build a solid object from them?
Message 4 of 9
JDMather
Once you have replaced your 3D sketch with proper 2D sketches - I would use the Loft command.
Post your new attempt here if you have trouble figuring it out.
Message 5 of 9
Cadmanto
My first thought is to use the sweep command.  Use the green lines as your guide curves and the purple as your profiles.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 6 of 9
robm1983
in reply to: Cadmanto
Thanks for the suggestion. Loft and 2d sketches seem to work... only not sure how to make the rounded tip... any idea?
Message 7 of 9
JDMather
You would Loft to the Point.
I started to fix it up for you, but not only are there no dimensions - you are missing horizontal and vertical constraints that Inventor should have done for you?
And the lines in Sketch2 are not constrained to the lines in Sketch1 (Project Geometry).
Message 8 of 9
robm1983
you're right, didn't know I can loft to a point 🙂 I'll show how it turns our shortly. Thanks guys.
Message 9 of 9
JDMather
I recommend that you go through this Tutorial - http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%202011%20Tutorial%2014.pdf
it demonstrates how to use a 3DSketch in a Loft and how to Loft to a point.
