I cannot make a plane parrallel to a surface and through a sketch point.
I can't also select the sketch point or line in order to make an axis. the sketch point, line from the sketch or anything from a sketch isn't selectable
Attach the file here that exhibits this behavior.
Try a work point instead of a sketch point. Post your files or a shot of what you're trying to do.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
This would be an interesting item to add to Ideastation.
Thanks!
