Inventor Forum
how to make a flat of this part??
4 REPLIES 4
jainildesai
561 Views, 4 Replies
I Am trying to make a flat of this attached part. The dimensions are correct for the part but I am trying to make it such a way that I can form it using a die with a press break. I tried many different ways but inventor dosent seem to allow me to create a lofted flance using a 3-D profile sketch. any ideas on how o get this part modeled as a sheet metal and have a right flat opattern?
4 REPLIES 4
jletcher
in reply to: jainildesai
can you post a picture have not Loaded 2013
blair
You might be able to get this to work using the "Rolled" function within the Sheet-Metal portion of Inventor. You won't be able to get it to work using the 3D Sketch and Sweep.
I really think that this is outside the scope of the Sheet-Metal module in Inventor
Delta Tau Chi ΔΤΧ
Mark_Wigan
ie, if the part relies upon the deformation of steel (as usually happens for complex shapes that are not split, formed and re-welded) then it cant be calculated by conventional means.
best regards,
- Mark
(Kudo or Tag if helpful - in case it also helps others)
PDSU 2020 Windows 10, 64bit.
M.Peppel
Hi Jain,
for parts like this you need a special set of tools to unfold them. There are several out there as to name the first three on my mind:
FTI Forming Suite
3DQuickpress
Logopress 3
Regards
Matthias
Nihil Ex Nihilo
