Inventor Forum
How to make a cut in a cylinder in a 45 degree angle
7 REPLIES 7
Message 1 of 8
8167 Views, 7 Replies
I am trying to make a cut on a 12" D cylinder at a 45 degree angle and i am having a little trouble. I have projected the shape onto the curve and sketched it. Now to finish the cut do i need to scuplt that path or how do I go about doing this. I may even be going about this the wrong way.
I provided a screen print to try and and explain it a little batter. The half moon lookin sketch is what i am tring to cut out of the cylinder. i have already projected the surface lines on the cylinder, but get stuck at this point
 Any input would be great!
thanks,
Seth
7 REPLIES 7
Message 2 of 8
R.Corriveau
Emboss?
Message 3 of 8
in reply to: R.Corriveau
Yes, Emboss does work, but I need to Emboss the the radius (7.375 noted on picture) into the cylinder.
Does this make any sense? I may not be explaining it as thorough as I need to be.
Message 4 of 8
R.Corriveau
Emboss should work for the rad. Did you try the "wrap to face" option?
Message 5 of 8
JDMather
Attach the ipt file here if you can't figure it out.
Message 6 of 8
in reply to: JDMather
Message 7 of 8
JDMather
I could be completely lost here, but check attached.
Exactly how will the feature be manufactured?
Message 8 of 8
Thats exactly what i was looking for!
Seth Sneeringer
