I am trying to make a cut on a 12" D cylinder at a 45 degree angle and i am having a little trouble. I have projected the shape onto the curve and sketched it. Now to finish the cut do i need to scuplt that path or how do I go about doing this. I may even be going about this the wrong way.
I provided a screen print to try and and explain it a little batter. The half moon lookin sketch is what i am tring to cut out of the cylinder. i have already projected the surface lines on the cylinder, but get stuck at this point
Any input would be great!
thanks,
Seth
Solved by JDMather. Go to Solution.
Yes, Emboss does work, but I need to Emboss the the radius (7.375 noted on picture) into the cylinder.
Does this make any sense? I may not be explaining it as thorough as I need to be.
Attach the ipt file here if you can't figure it out.
I could be completely lost here, but check attached.
Exactly how will the feature be manufactured?
