Inventor Forum
How to make a crimping mark on c-section channel surface
14 REPLIES 14
Message 1 of 15
462 Views, 14 Replies
I model this c-section and the crimping tool. But I can make a crimping mark on the surface. I have tried Loft, Punch Tool, Sweep,..., but they didn't work. Could any one help me?
14 REPLIES 14
Message 2 of 15
CCarreiras
Hi!
It's so much easier if you had done the part with loft flange ... at least you had the correct flat pattern.
CCarreiras
Message 3 of 15
in reply to: CCarreiras
Hi Ccarreiras,
Thank you for replying my post.
I did try Loft. But it seems inventor can't solve the complexity surface. I forward the model for you.
I did successfully made the middle part witch has a crimping mark, but I cant add 0.9 cm thickness on it.
Are you able to check if it my model's problem or the inventor's capabilities.
Regards
Message 4 of 15
CCarreiras
Hi
Your part... with a lot of surface work.
Drag the end of part to the end of the browser and wait a few minutes and your part will appear.
file in attach.
CCarreiras
Message 5 of 15
Hi CarlosC,
Great job! I've been caught by this problem for 3days, you solved it in no time! Awesome!
I lofted it in 3 different parts then assemblied them together. I can only use "surface" out put, no "solid". Here is the part I made. Could you look at it and point out what is wrong?
And, are you make the crimping mark in R4 radius? My press tool will be made base on this part.
Regards
Jiming
Message 6 of 15
Hi CarlosC,
Here is another one.
I assemblied Loft4, Loft_Middle & Loft_LH into one part. I knew it shouldn't make the part like that. It must be something wrong when I Loft them.
Could you sent me the part you made.
Regards
Jiming
Message 7 of 15
CCarreiras
Hi!
I cant open the assembly... missing the files ROTA90_LH.IAM and ROTA90RH.IAM.
I think you are entering a field that you don't dominate. These join between that surfaces is not easy. You have to do a little work with surfaces.
Take a look to the model attached...
Don't forget to drag the "end of part" until the end to see the part. (do you know what im talking about?)
CCarreiras
Message 8 of 15
Hi CarlosC,
I made one. Not the assembly. Fully use loft to generate. But the bottom of the part have exceeding material, making the bottom uneven.
I will email you the model.
Regards
Jiming
Message 9 of 15
CCarreiras
HI!
Great!!
Show me!! i didn't receive the email.
CCarreiras
Message 10 of 15
CCarreiras
HI!
You can drag the "end of part" to the top of the operations, the file will be a lot smaller, and then you can place it here.
CCarreiras
Message 11 of 15
Hi CarlosC,
I will email you the final edition Monday, as my files are in the company. I don't have it home.
Regards
Jiming
Message 12 of 15
Hi CarlosC
Maybe the file is to large. I can't attach the here.
I just relize that I don't have you email address. Could I have yours? So that I can email you the final edition.
My email is, jiming.zhang75@gmail.com.
Regards
Jiming
Message 13 of 15
Hi CarlosC,
This is the final model I made.
Regards
Jiming
Message 14 of 15
Hi Ccarreiras,
capabilities.
Regards
Jiming
Message 15 of 15
CCarreiras
Hi!!
It's due to some corners. You have some exterior rounds with 0.9 radius.
When you apply 0.9 thickness for the inside, these radius have some issues to solve, because they became 0 in the interior.
Solution: You can manually create some of this surfaces, based in others with 0.90 thick, or you can increase the exterior radius to a little bigger then 0,90 in problematic corners.... like 0,95 for instance.
Take a Look in my model. and observe how I thicked the two parts first before the center loft.
I know my way will take more time and work, but i think the center loft will become more realistic..
CCarreiras
