Hi boys,
I have a question, need help sure
How I would wrap/coil a tape around this attached picture?
You see the rounded edge, it's not fully circle
Solved by CCarreiras. Go to Solution.
Check out this link and see if it helps you.
http://www.youtube.com/watch?v=q4htnkH2H1k
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Hi!
I d'ont know any tool to make this automatically.
Most of all, 2D and 3D sketches ... with a final sweep.
I made one manually, just for curiosity... it works well... see the file attached..
Note: You can went to the Parameters table and operate some changes.
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
I forget to mention, the rectangular that I have its end not like his start.
Start with rectangular dimension for example 4 x3 but it end with smaler dimension for example 3 x 2.
How would the rectangular now folow the shape?
Sorry for this complexation
Regards
Sohaib
Loft or Extrude with taper the "tube" as a surface body (increase size by radius of swept feature).
Coil line as surface body.
3D sketch to find Intersection Sweep Path.
Workplane perpendicular to beginning of Sweep Path.
Create profile and Sweep.
HI!!
I dont have 2012 version installed.
I left you the browse three to help you following the construction of the coil.
The steps are described in JD post above.
Hi Carlos,
Thank you for your efforts and time.
JD, Thank you too
Many thanks.
Regards
Sohaib
